OK, now we're closing in.Yes I have stop lights
Having stop lights means the wiring to the lights (at least the rear anyway) is intact and working. Also means the rear bulbs are working too.
The power goes to the flasher and that feeds the switch, and you said you have power there (I assume it's flashing power), so we're good for power leading to the switch. If the power isn't flashing, then you have to go back and check that.
Put a tester to the output line from the switch and i have power going in and power come back out.
This bothers me a little and why I would want to know if that is flashing or not. You said you plugged in the flasher and it worked, but looking at the timeline, I'm not sure which wire you took your power readings from.
If all the wiring is correct, it points to the switch being the problem. But! Since you've said that you do some rewiring, I'm a little hesitant to say that is 100%.
