70bigblockdodge
Just because you turn the adjusting bolt does not change the Rockwell's of the torsion bar itself.
Trust me the shape of the control arm in each of those is the same, although a sketch it was done in a CAD program, the element was rotated 9 degrees each way.all I see in that photo is the control arm flexing
Not as critical on suspension with lower ball joint carrying the load and top ball joint for alignment. Those up high springs are less than ideal.keep in mind that the ball joint neutral point will be off and will pivot differently and that it wasn't designed to be run at the angle it would be once the T-bar is backed off...
It may or may not be an issue but it may wear at a different pattern and stress it as well.
I recall having some aluminum slots on a 68 Cougar with a offset (tires stuck out more than the stock steelies) that stressed the hell out of my new ball joints and the joint ended up lasting for about 1 summer
What it took for me to come 100% around was looking at your illustration even further and having me realize where the fulcrum really was, not where I thought it was.Ok, I think I can take care of Stan's other 2%.
So will Stan be slamming his Formal in the near future and adding 22" wagons to the equation?What it took for me to come 100% around was looking at your illustration even further and having me realize where the fulcrum really was, not where I thought it was.
Thanks. Excellent illustration.
You are only compressing the shock 50% of the wheel travel. So a 2" drop will just compress the shock 1".So I'm ready to be tutled on this subject
If a lower stance is desired then would shorter shocks be in order?
Or would it be recommended that the other lengths be available for Dukes of Hazards jumps so full suspension travel is still available?
Talk to the next owner.So will Stan be slamming his Formal in the near future and adding 22" wagons to the equation?
