Do you feel lucky?This makes me worried about a job that I have been putting off. I have a mild Comp cam and lifters in my convertible. A few of the lifters don't stay fully pumped-up once the engine is hot, make a clatter under the hood, and the the engine has a bit of rocking at idle. It hasn't gotten any worse over time but is frustrating. I bought some lifters off Rock Auto to swap-in and break-in the cam again with those. They are Sealed Power lifters.
Do you feel lucky?
The Rock Auto lifters are also going to be ChiCom units. And you do not want to put new lifters on a used camshaft as that will always end badly.
I will not mention some of the stuff I have gotten away with then.The Rock Auto lifters are also going to be ChiCom units. And you do not want to put new lifters on a used camshaft as that will always end badly.
In high school 3 of us shared a hot cam in 3 different cars over about a months time. We were alll just trying to make our cars as fast as we could with no money. We didn't change valve springs or anything, I don't even think we matched the lifters up to the corresponding lobe, cam is still in a 383 in a barn in Michigan in my old 68 Sport Fury. My friend still fires it up once in a while, still not flat.I will not mention some of the stuff I have gotten away with then.![]()
Same stuff, with a fancy box. Only lifter I have ever had a problem with was a Comp. The cam was a ancient Crower piece that the lifters went rusty in their box. So I bought a set of Comp lifters. The lifter was rotating, the bottom just wore really strange and fast. It never gave a problem but the engine started having idle oil pressure problems (crank was worn so bad the clearance was enormous) came apart for a freshen up.Comp Cam stuff probably isn't much better.
He made the clutch pedal out of a spare brake pedal and some flat steel for brackets. That's my kind of cheap!That Tony guy doesn't give a crap about being fancy. 4 door B body? sure, lets put a 4 speed in it and beat the piss out of it.
Old bearings, old rings, loose is fast and you need extra ring gap for the spray. Gotta love it!![]()
