ceebuddy
This is from the 1972-6 MTSC:
"The water valve used on these models is a combination bypass and flow valve. The flow part of the valve is fully closed by moving the temperature control lever all of the way to the left. This shuts off flow through the heater core. The bypass part of the valve is a spring-loaded poppet. When the flow valve is closed, coolant pressure opens the bypass and coolant returns to the engine without going through the heater core. The pressure-operated bypass valve automatically compensates for changes in engine speed and coolant pressure. This bypass feature results in very good coolant volume and temperature control."
