Welcome Elizabeth to FCBO!
Awesome i will check as soon as i get home ..Thank you
Is there a way to get a list of all the original parts used ?
So i was able to find this with a vin my question is why dont it say FuryIII
My title and regiatration does ??
The fender tag is a metal tag about 2" x 4". It is located in the engine compartment either riveted or screwed to the inner fender on the driver side.
Welcome and nice looking car.
Please note Elizabeth, the fender tag on your car is found on the radiator support near the battery, it will have a bunch of three digit numbers and letters on it. If you take a pic of that, then we can work out what you car originally was built with. Cheers.
What he said. . . And welcome to FCBO!
I am really confused now so i checked my vin# and it came back with this info
It showing it a Plymouth fury grand coupe/ Sadan
Which is not the same as a plymouth fury III
Ao i ran it with make and model and it is telling me that only a 2 door hard top coupe can have the 383 cid 290 but mine is a 383 convertable
This is what the fender tag will look like. And when running the numbers, if it comes up invalid switch the o' and zeros.
VIN decoding from the 1970 Parts Manual. You can download the parts manual from mymopar.com
MyMopar - Mopar Forums & Information - Parts & Accessories Books
As you can see your VIN PM27L0D126629 would translate to:
P – Fury
M – Medium which is also the Fury III in 1970, PH = Sport Fury, PP = VIP, PE = Fury I, PL = Fury II
27 – Convertible Coupe
L – 383
0 – 1970
D – Belvedere production plant
The Fender Tag will be located on the radiator support. When looking into the engine compartment, it will be to the right of the radiator.
It will look like this.
Notice the VIN is on the bottom right of the VIN tag that you can see on the dash through the windshield.
If you take a pic of your fender tag, some options can be decoded from it. If you find the broadcast/build sheet, it will give you all the information that the factory used to build the car.
