What is happening when a brake cylinder retracts slowly causing the brakes to drag?
Probably need to replace the rubber brake line going to the back or that one whl cyl. It has delaminated internally, making a check valve internally.
Ok thanks, just replaced the hose and get the same effect. Now onto getting Les' puller.
