Just curious. What year, what engine, and what trans? That trans looks "Odd Ball to me 'cept for the drum parking brake in the tail shaft. That makes it early '60 something with the set up for a trunion joint, Jer
With the bell housing removed, you can see where the bolt goes. When it is in all the way, it will be flush with the edge of the flange on the block. You can see there is no room to get a box end on it, or really an Allen key, to get it started. Can’t get your fingers in there when there is a bellhousing. They must have had one killer specialty tool to get that in there.I'm kinda shocked myself nobody has been able to help out on this.
Something else is going on, methinks.
Any chance of some sharp close ups?
You are on the right track. I did find a special tool listed in the shop manual c589 I think, and someone else somewhere else cross referenced that to a 10” snap on tool. But I thought they still put the TC on first and the tool worked for both. Someone else suggest a funky long nosed round head needle nose pliers. I have those and will go try first. Otherwise I found a number of items similar to snap on tool for getting up there.Sorry to tell you this, but I think the TC is going to have to come off then put on after the bell housing is bolted in place. Now I remember fighting with this on a '60 Desoto we bought for parts years ago. You will need a Snapon extra long wrench to put the bolts back in the TC. Theirs are longer than anyone else's. Even their standard wrenches are longer than most everyone's regular ones. A zero degree offset boxend wrench might work....
At least you will have access to those harder to get ones that are being blocked by the TC.
Just my opinion, for what its worth.
That might work too. I could tack a nut to the inside and bring in a bolt from the other side. I can finish the nut with a off set open end wrenchI'm thinking that a stud and nut might work out there.
An idea... Screw the bolt in from the other side rather than making a stud. Might be able to screw it in and catch the nut as it goes in. Screw it in as far as you can and then tighten the nut.
Tried that. Lots of room in those slots. They are not tight. The play in them - a good 1/8 turn.Just had another thought..... Try turning the crank, thereby turning the TC, so the dogs /slots in the TC mate with the dogs/slots on the front pump of the trans. Have a buddy gently push on the rear of the trans while doing it.
definitely not. that's a last resort for a skilled hand. if possible, if not done already, do a trial fit of the converter to the transmission. put some white grease on the seal area of the converter. if the converter installs completely, the front seal will sweep it. put line up marks on the converter and trans. that'll give some idea where the pump to converter alignment area is.Tapping with a mallet not likely practical.
