It is a Crown
It might have been off before I changed the bearings, I never checked it ahead of time. But I wonder how the old factory bearings compare to the new replacement bearings? Are they exactly the same specs or are they just close enough to work? If they are not the exact same width it will change the end play. What was in mine for bearings were not factory I don't think, seals look a little to good to be factory.
Book calls for starting with a .040 shim on one side then shim the other side as needed, mine has a .020 right now on both. Passenger side is all bolted together with the .020 shim and I slid the driver side in with the race flush to the axle flange, no shim and I still had way more them .018 just by feel, didn't measure it. If I get time tonight I will finish it up and get the dial indicator on it, but I am thinking I am going to have to take all the shims out to get close, we will see.
