Wheel well rubber front end...
74Monaco CHP
Hudson Valley NY
Trying to find a diagram for front wheel well rubber. I have a new set to replace mine which were missing just can figure out where they all go .
There appears to be 5 sections for each side of the car. Thanks
Megasize: http://i42.tinypic.com/1566zyf.jpg
Its like a jig-saw puzzle. I try and get a picture up.....I've found a bunch of the clips in place luckily.
I think two might be for the header panel sides and two are the strips along the frame and fender well.
Thanks
Quite frankly, I'm baffled about what rubber you are talking about. I can't think of any rubber except for the upper control arm flaps...
Well I found several pieces I tracked down out under the front header...looks like they close in the radiator and related area.
I think I will wait until I change out the old grill for new.
I'm going to put the car up on ramps to see from underneath. I bought them brand new for an Imperial. The biggest problem is finding the holes for the push in clips in the k-frame. Yikes.
OK. Now I know what you're talking about. It's the rubber panel that closes off the gap between the bumper and the plastic radiator lower splash guard. You're in luck. I've got the car up on the lift as we speak. I'll snap some pics and post them tomorrow.
Thanks I see it can be scrunched up a bit.. I'll get back to you on one of the odd shaped ones.
I have seen literally hundreds of them. They are all scrunched up. That's the way they came. Stupid design oversight by the engineers. I'm willing to bet on the pre-production models, the assembly line workers told upstairs about it but... how was it said earlier?... they were barking at the moon?
