WANTED WHEELS AND HUBCAPS
São Paulo, Brazil
Hi all
I need 04 original steel wheels (part number 3580062 I believe) and 04 hubcaps (part number 2944444) for my 1973 Imperial.
Wheels do not need to be perfect...just in a good shape, but the hubcaps need to be in pristine condition.
If you have them, please send me a DM.
Thanks
Andre
Wheel Vintiques sells the Chrysler "cop car" 15x7 wheels as repro items. You can either get them directly from Wheel Vintiques or from Summit Racing. Be sure of the bolt pattern on your car as some Imperials had something other than the normal Chrysler bolt pattern of 5x4.5".
Then add the correct wheel covers to them.
Hi all
Thanks
Andre
Email Murray Park.
Www.cbodies.com
Thanks a lot !!
For your consideration. My post on B bodies.
As price seems to always be an issue, I have a full set in their dirty used but straight condition for less.
And yes, check bolt pattern. Imperial is usually 5x5"
5x5 bolt pattern then opens up to 1/2-ton Dodge trucks, starting in perhaps the early-mid 80s?
Should be easier to find.
