Oct 26, 2024 #1 P polarnj Active Member Joined Sep 25, 2024 Messages 337 Reaction score 70 Location NJ I would like to do this but don't want to end up with a hood that won't stay up or doors that won't stay open Where do you lube these things?
Oct 26, 2024 #2 Toolmanmike Moderator Staff member FCBO Gold Member Joined Oct 25, 2019 Messages 2,073 Reaction score 2,116 Location Iowa Lube at every pivot. The spring and lever design keeps the hood up and not the drag on the pivot points. Same with the door hinges and latches.
Oct 26, 2024 #3 P polarnj Active Member Joined Sep 25, 2024 Messages 337 Reaction score 70 Location NJ Toolmanmike said: Lube at every pivot. The spring and lever design keeps the hood up and not the drag on the pivot points. Same with the door hinges and latches. Click to expand... Ok so basically just oil everything wherever there's a pivot point?
