DonnieRockett
so the hot cold slider on the climate controls is completely stuck on the hot side. it will not move. i'm going to look through the online manual, but has anyone else dealt with this issue?
Is the water valve controlled by a cable or is it controlled by vacuum like my '70?As I recall, the heat cable goes directly to the water valve.
Easy enough to test functionality, even during cool weather. Turn it on, look under the hood & see if the compressor clutch has engaged and spinning when engine is running. If so, touch the condenser core in front of the radiator after it runs a few minutes. Is it hot? Feel the silver pipes running into the AC evaporator box on the firewall (AFTER the expansion valve/receiver-dryer cylinder) are they cool to the touch?found the cable in the engine compartment, worked it back and forth from there, and now the slider works! all good, just need to wait until the weather warms up to see if the AC actually works.
