Ok, I see that but then why is there continuity between that wire and slot #28?
Continuity is kind of tough to analyze sometimes. Most likely this is some sort of feedback through the starter solenoid coil or relay coil. You really can only do continuity through a disconnected wire. I should have said mentioned that.
This is where voltage drop tests are more conclusive.
I don't have that 16DBL dark blue line at my relay as can be seen in the photos. If I took off the lines I added then you would see just one large red wire at that position. In fact both the 8-129 and the 8-148 show two wires from there despite me only having one. I'm going to have to cut open the wire loom to see what is in there. 8-129 shows a junction splice right where you drew your yellow line. Is this where the dark wire to slot #28 originates from as it isn't the relay?
OK, I understand now. This is tough trying to communicate through the forum sometimes. If we were sitting at the kitchen table with a printout of the wiring diagrams and some markers, we could get through this easier. I'm trying to do the same here with my marked up pics. Some of it is so I understand and we are on the same page.
So....Let's assume that we have the "65" amp alternator circuit in 8-148. In running through the circuit, it looks like there's two "red" wires as you say. One is obvious and goes to the battery through a fusible link. I've highlighted that one in pink.
The other goes to a couple splices (1 and 3) and goes to the alternator and goes to #9, #13, and #16 on the firewall. That is in red.
Again, you may have to not think color but think about the routing. What does the green fusible link run to?
What happens if the relay is toast? Do I have a 65 amp alternator? I don't have the secret code for the numbers.
The broadcast sheet shows a 60 amp alternator. That would make some sense, but the wiring diagram references a 65 amp alternator. I looked in the FSM and I don't see a 65 amp alternator in the specs. It's probably safe to assume that "65" is another FSM anomaly and it really references the 60 amp alternator. As far as the relay, I think there's a real good chance it's bad. It would not cause the issue you are having, but you have had to bypass it with a remote starter switch. That kind of points to a bad relay.
