z bar - 68 fury III - alternatives, pictures, dimensions
Thank you for your contributions and pictures. I have managed to assemble everything i need minus a z bar to to convert my 68 Fury to a 4 speed.
Has anyone used an a-body (short tailshaft) transmission and just got a longer driveshaft?
For the Z-bar, I used a B-body. Cut a section out of the middle and then butt weld the two ends together with the correct indexing.
As far as shorter tailshaft/longer driveshaft, it doesn't work that way.
What's different? Shifter location and trans mount? I saw the B/E shifter location you posted in a different thread. As Doba used in a different post teach me Obi-wan.
The distance from trans mount to bell housing pivot is the same no matter the trans body style what ever. Mainly because any trans went in any body, forget the A body trans the shifter mount is totally wrong but yes it will go in a C body, mount to bell housing are same. The only thing that changes is the distance or length of Z bar from bell housing pivot to frame bracket. The other body variable is pedal to Z bar rod mainly from the way the pedal hangs to frame type. I replace that rod with a threaded rod and heims ends the adjuster section that goes from rod to clutch fork can be done this way also. The clocking of the levers on the Z bar is pretty close to the same if not identical remember the clutches no matter the body style is always the same distance from transmission mount.
I'm trying to verify the z bar that I have is the C-body one. I'm unable to accurately determine the
overall length of the tube from the above pictures.
The tube on mine is 9-15/16" long. Is that the correct length?
Correct me if I am wrong but I believe there were two different C-body Z-bars. One for the three speed manual transmission and the other obviously for the 4 speed.
I am looking for ideas/suggestions on obtaining a z-bar for a 68 fury 4-speed swap.
Is there something similar that can be used, or modified to work?
Does anyone have pictures that could be used to guesstimate dimensions and angles from?
Is there a place where someone could find manufacturing specs?
Thanks for your help on what is probably a worn out topic, but I searched the forums to no avail.
do yourself a favour and go with a hydraulic clutch setup. no ******* with z bars geometry and hours of pissing around. trust me. I have a hydraulic setup on my 35 Plymouth streetrod and it works flawlessly.
