- Joined
- Nov 14, 2010
- Messages
- 28,231
- Reaction score
- 27,572
Not mine but couldn’t help but notice the wheels.
1967 Ford Country Squire Wagon-new price
1967 Ford Country Squire Station Wagon. Woody. Based on Ford Galaxy. It has a FE big block 390. Pulled from real barn after an eight year slumber. It is a project. IT RUNS!, but will need gas emptied from tank as has been sitting, a tune up, etc. The brakes were new with only a few hundred miles on them but, that was done probably 10 years ago. I had the top end redone after I bought it. It has a pertronix ignition and an electric fuel pump. I think some minor tinkering will get it on the road. That said, It will still need towed; that whole sitting thing again. The interior is in OK shape. Couple of small tears in upholstery. The dash and carpet are toast. The headliner seams in back have come undone. There are a number of companies that have reproduction parts, even interior. The underside is pretty clean and has no holes in floors. There is a small hole in frame rail on drivers side, under front door. When I got it, it was leaking brake fluid on it and helped to eat a hole. Also, the spare tire holder has rusted out. It was side swiped before I got it. I have a replacement panel. It's huge, as it was cut off another wagon. It will fix, not only the side swipe but also the leg in front of tire; that is the only major rust spot on exterior. I have a number of parts that go along with it. A set of tail lamps to replace the damaged one. A few chrome scripts for exterior.
Ready to let this go. $2200 down from $3000. Come and get it.
