For Sale ‘66-? Fan shroud 2579011
haywire 440
Get The Cartwright
Arkansas
Feedback: 9 / 0 / 0
These are 2 plastic fan shrouds, should be 26”. They are solid with no cracks, Part #2570911. The might fit a few models including ‘66 New Yorker and ‘67 Newport. $90 plus the ride.
Shroud cleaned and inspected. Looks in vg condition.
Paul 66, you have first dibs on a shroud, I will pm you tomorrow with a total. Parts will be combined.
As far as I know it will fit the ‘66 NY & ‘67 Newport. Maybe someone here would have an opinion. If you have a factory service manual,that would list your shroud number.
I don't have a manual. You wouldn't happen to know the bolt measurements would you?
Mine is 13 1/2 from top to bottom hole and 27 1/4 from side bolt to the other side. 22 inch core radiator
Measurements, 1.top hole to bottom hole 16 1/2” (8 1/4” in between). 2. Side to side 24 3/4”. 3. Diagonally 30”.
It will not work in your applications. This is for 26” radiator and yours is 22”.
