So I had a runaway temp issue when I installed the AC. Thats why I have the cnc impellered flowkooler pump as well as now some high power mishimoto fans and a perfect fitting shroud.
My theory was, if the coolant circulates til 195 in the engine and then slowly lets coolant from the radiator circulate, I could set my fans to come on at 200 and have longer cooling in the radiator no?
Anyway, I think I dont even need to think about it now, its 80° outside and It ran 207 the hottest with AC running!!! Thats perfect. Will probably be 220 if the temps reach 100° here but thats rare now. The kicker was, I have one of those stsnt rad caps that have the lever. With the lever closed, the gasket barely made contact to seal the radiator so I had to modify the stants plastic lever to have the spring push down further to seal it. Would have never found that If I didnt squeeze the upper hose cold and heared the air... So check your parts and verify fitment!
