1965 Plymouth fury rear brake shoes
bub rollins
ohio
I have a 1965 Plymouth fury sport and I purchased new brake shoes that matched the old ones 11x2 and they are exactly the same shape but were the pad is attached to the shoe is different and will not allow the drum to go back on. Any help or advice would be greatly appreciated thanks
I purchased the new rear shoes at Oriely auto parts
Did you back off the adjusters? Is the parking brake partially on or the cables stuck?
Yes it has all new hardware and fits fine with the old ones. I called Sumit racing and jegs to try a different set and they don’t offer 11x2 for that car only 11x2.5
Make sure you read the factory service manual. Has opictures how it should be. If you don't have one, download from mymopar.com.
As Imperialist67 indicates to you ^^^ above ^^^ ,
I have *** N.O.S. *** Asbestos *** 100 % correct *** Brake Shoes —- not the new - fangled Chineseum garbage you just acquired ……. And
The *** 100 % correct *** 11 “ x 2 “ Brake Hardware ***
P.M. me, as per forum rules, if interested……
Craig….
I have all of your 11 “ x 2 3/4 “ Front Brake Parts ALSO ……
