I recently acquired a 1966 Newport with the stock 383 2-barrel engine.
I noticed that the spring and counterweight are missing on the exhaust manifold heat riser mechanism. Does anyone know which way to turn it so that it stays open?
I found this thread, but there was never a definitive answer:
Chris
So, today I checked the manifold heat control valve on Rosie, a '67 383 Fury. It was stuck but seems broken because it when I freed it with penetrating oil it rotates but has no spring action to return it to open. Now I am concerned that besides not working, I have to assume it was stuck in the open position.
I got out the shop manual, it indicates full clockwise would be the run position. But now that it's moving freely will it vibrate to close position?
What signs or symptoms would I be looking for if it was stuck closed?
Also, do I really need this feature?
- Gonzo
- Forum: Early C Bodies - The Slab Side Years
Chris
