- Joined
- Nov 14, 2010
- Messages
- 28,564
- Reaction score
- 28,448
That’s late enough in ‘70 that it could be for the ‘71 model year.
That’s what I thought.Nope. The door lock itself when pushed or pulled activates the power lock plungers.
A few additions from my opinions to populate the list.PM sent. As for the tag decode, this is what I get:
Here's what I get:
a6 -
b5 -
d6 -
h7 -
j4 - pretty sure it's a side-trim code
k7 -
u1 -
A1 -
H2 -
J4 -
K8 -
R2 - radio (am with front/rear speakers) or maybe FM radio?
S1 -
X1 - all tinted glass
A4 - 3.23 rear axle
X8 - sure grip (!)
TRM - P6R premium grade vinyl on the bucket seats, red interior
PNT - WW1 (monotone white)
UBS - H (upper door frame paint) H is Tan?
62 - 383 4bbl
5 - automatic trans
635 - 8.55 x 14 tires white wall (4 + spare?)
C19 - December 19 (scheduled build date)
It's a Monaco 500 (console, bucket seats, fender turn signals, wide side trim). Was the 500 package indicated on the TRM code? Was the 3-spoke steering wheel part of the 500 package? Or did all US Monaco's get that, regardless of trim level, and Polara's (and non-500 Canadian Monaco's) got the 2-spoke wheel?
One of those codes is going to be for A/C. Another code for power windows. No cruise control, no tilt/tele steering. No bumper guards. Check for power (vacuum) trunk release. Does it have shoulder belts? Has the radio been pulled from the dash? Almost certainly made at the Belvedere plant. I'm guessing the vin is going to be DP23H74xxxxxx.
My 67 Polara 500 convertible carried j4 code for body sill molding, even though that molding was standard with the 500 package, and runs along with wheel well moldings.For this car, what we don't know the codes for:
- power door locks
- right side rear view mirror
- seat head rests
- side trim
Based on my car's relatively few options:
j4 - door sill molding
g2 - unknown
w6 - Canadian spec
g2 is a candidate for bumper guards
My car had the regular (narrow) lowerside trim, and the 1" wide belt-line trim, but there doesn't seem to be an option code for that?
Does the DP23 automatically code for Monaco 500 which by default indicates the wide body trim, so no other tag code for that is expected?
My guess is that d6, k7 and H2 must codes for some combination of power locks / right-side mirror / head rests.
R2 codes for the higher-power (but still only AM) radio, which must include the rear speaker and dash-mounted fader dial.
Does this car have shoulder belts or power trunk or rear window fan? Build sheet?
I think something fell on the trunk lid to mangle it like that.
Keep in mind 1967 was a transitional model year .For this car, what we don't know the codes for:
- power door locks
- seat head rests
- side trim
g2 - unknown
w6 - Canadian spec
I have a j4 on my other very low optioned 500.
Yes, those are the options it has..Does your black Monaco have a 26" rad, with bucket seats, driver's seat is powered? AM radio with no fader and no rear speaker? Fender turn signals?
Yes well let's continue to figure out what all the tag codes mean for '67 shall we?
I get it that the car might have something that isin't coded on the plate. But is the converse true? Would they stamp something on the plate that has no connection to a feature on the car?
And a side question - were these '67 fender tags layed out the same for all Mopar cars? Same set of rows? Chrysler / Dodge / Plymouth? Did X always code for window tinting, R for Radio, regardless what '67 car we're talking about?
My car has g2, still don't know what that is. Would the A/B/E body crowd have that figured out?
Are there definate examples of how Windsor and Belvedere differed in terms of '67 C-body plate codes? I think they used different formatting for the wheel/tire codes.
And what is the sill molding?
Is it what you see when you open the door?
Or is it the long piece under the door that runs from wheel to wheel?
www.forcbodiesonly.com
Thanks for chiming in!I get it that the car might have something that isin't coded on the plate. But is the converse true? Would they stamp something on the plate that has no connection to a feature on the car? No. Defeats the purpose of the tag. The tag is, generally, a traveling durable way to communicate modifications to the body (holes, moldings, brackets) trim and paint. Adding codes not related to these guidelines would only confuse the process.
were these '67 fender tags layed out the same for all Mopar cars? Same set of rows? Chrysler / Dodge / Plymouth? Did X always code for window tinting, R for Radio, regardless what '67 car we're talking about? Yes. The 67 ABC tag format is the same for all plants, makes and models. Coding is generally consistent for all cars. There are some variations.
Are there definite examples of how Windsor and Belvedere differed in terms of '67 C-body plate codes? I think they used different formatting for the wheel/tire codes. Yes. There are differences between the plants. Windsor uses a two digit tire code, Belvedere uses a three digit code. Windsor uses w/6 and w/8 to distinguish between US and Canada bound cars. The Windsor plant VON and VIN series are different depending on whether it was built for sale in Canada or US. (we had a very fascinating comparison at last year's VOLO show between two Windsor built cars. One was built for US and one for Canada.)
And what is the sill molding? the molding under the door
Cdn cars used philips head screws on the tag.
Belvedere used rivets
Both tags here are Windsor cars, but 2nd tag is a US car.
Yes both say MADE IN CANADAI assume that both VIN tags on those cars say "Made in Canada"? Did they both (originally) have US-style Monaco tail lights?
Besides the W8 stamp on the tag, what exactly made it a US-spec car? I'm not doubting that's what the W8 is meant to denote, I'm curious what technically would have been different about it.
Having a different VIN pattern is largely irrelevant (or - to be expected). There has to be something more substantial to make it a "US-spec" car - no?
Then in 68 the first two letters of VIN was same on both sides of the border,lol.The different VIN pattern is not irrelevant nor unprecedented.
Different VIN assignments would be a way of managing any parts specific inventory as well as any accounting for any trade agreements in place at that time. One would be able to track how many cars stayed in Canada and how many were shipped to the US.
The different VIN assignment is a good example as to why the VIN number is administrative and not related to production.
I use dodgecharger.org for '66 & '67 cars.I appreciate that! Can you recommend a good online decoder to look these tags up?
