Is it 383 or 440?
Thanks,
Tom Denkler
Thanks,
Tom Denkler
Hmm, that's weird. Maybe bugs or varmints ate it? No evidence of a fire under the dash, is there?Yah it is still soft too, but the weird thing is the foam on the inside has melted away or someything leaving the pad hollow, i have wondered if there is a way to refill the foam using a can of spray foam?
Thanks for the generous offer, partner!:wtg: Unfortunately, I'm about 1,000 miles away from you, so it's not really feasible right now.If you want to come take it out you could have it for free since it would need work to make it usable.
Ill check these bits out today for you and get back to you this evening mate, cheers,Got a couple more bits I could use if ya got 'em. The rear view mirror assy. (if it's in decent shape), and the washer jug (if the mounting ears aren't broken off). Thanks again!
The only parts missing is the radiator and trim piece for the steering column. What state are you in?wollfen, new member and i would be interested as i also have 68 newport,whats left?
wollfen, im located at ewing mo.
