70NPORT
Yup....and that's a good thing.
Im definately interested in some items...I just started the new life of my 68 fast top...
ON Canada? View attachment 18297
I will check to see, i know one is bad but will get back to you, cheers.How are the fenders are they in good shape on the bottom where the trim is usually thats a good spot for a rust hole. I would be interested in both front fenders.
This car has already helped two other cars here on this forum, possibly three, including reds car that he sold, so its definitely having a positive outcome
That piece is a flexible material isnt it? The one in this car had fallen apart when i took it out.Do you have the piece that connects from the heater core box to the spot where the air flows from outside. It is a oval shaped tube.
I dont have the regulator but i can probably help with the rocker panel trim, i will take it off tomorrow and take a pic for you.Still parting??
I need the R.H. rocker panel trim pc. that is right behind the front wheel opening.
Also a manual left rear window regulator.
Posted via Topify on Android
Still parting??
I'm just gonna drive it as-is...
Yup definately different to my car, the bottom piece is a single unit travelling the length of the sill with the piece i showed you being a filler on top.Hmmm. Evidently they made a slight change to the 68's
Plus, it's the short pc. I need anyway. The 67's had six ribs.
Thanks anyway. There will be other stuff![]()
