Wollfen
The pivot points are broken on these.do you have the lock handle for the top that lock the top to the window frame driver side. need a complete handle with all parts
ok thanks for lookingThe pivot points are broken on these.
is the hood available?I have decided to give up on this car, I looked it over many times and there is just so much work in it, I have decided I can put my time
into better things. So I'm offering my gold 300 up for parts as is. It has no motor or trans or radiator in it, this is how i got it.
It has electric windows in it and power drivers seat too. This is a disk brake car as well.
Let me know what you are interested in and I can take pics.
View attachment 358964 View attachment 358965 View attachment 358966 View attachment 358967 View attachment 358968 View attachment 358969 View attachment 358970 View attachment 358971 View attachment 358972
I have a hood with one small rust spot on it, but the rest is in fine condition, I can post pics on thursday.is the hood available?
I do have a power steering setup, steering box and power steering pump, $100 for it all, I can get a pic thursdayDid you keep the power steering gear. What is it's condition if you have it and how much.
Here are the pics, the inner frame is solid but has a small area of rust on the drivers front edge, check the attached pic to see it. Id like $50 for the hood, its very big, would you be picking it up? I'm in 27837.is the hood available?
Here are the pics for you to peruse, the steering box already pulled out has more thread on the adjustment screw on top, that tells me it has less wear. The power steering pump will be the one on this engine.Wollfen your in box is full. Will be in transit to the Garlits Show Thurs Prefer to PM.
Would you sell the hood pad clips?Here are the pics, the inner frame is solid but has a small area of rust on the drivers front edge, check the attached pic to see it. Id like $50 for the hood, its very big, would you be picking it up? I'm in 27837.
View attachment 413484 View attachment 413485
THat's fine, let me get them all out and take a pic for you tomorrow.Would you sell the hood pad clips?
I don’t need the hood, will give you $25.00 for all the pad clips.
Thanks Galen from Tulsa
Here is the pic of the clips, they all came out fine and have solid pins still. I would say hit them with some rust converter or POR15 and they will last the life of the car.Super, I appreciate this.
PM me your e-mail for pay pal or I can send you a check.
I should have it here, I will check Monday.Did you keep the rear view mirror, or did it go to Bob?
$5.00 shipping is good.Here is the pic of the clips, they all came out fine and have solid pins still. I would say hit them with some rust converter or POR15 and they will last the life of the car.
You inbox is full, but lets say $5 for shipping and handling and I will take PayPal yes. PM me.
Here are the pad pics, it is damaged as you can see in the pics, it is also fragile and I'm not sure what the best way to pack it is, I could put it in a carboard box, but then it would get bounced around inside which I'm sure would destroy it.$5.00 shipping is good.
Text me your Pay Pal e-mail please and we will get this done!
918-892-8942
I can’t PM you.
It just says error and I can’t empty my box.
What a week!
Suggestion, Try rolling it around an old gift wrap tube, then slip it into a long narrow box. If you lay packing cellophane down before you roll it, it will hold it all together and keep those fibers from flying around.Here are the pad pics, it is damaged as you can see in the pics, it is also fragile and I'm not sure what the best way to pack it is, I could put it in a carboard box, but then it would get bounced around inside which I'm sure would destroy it.
View attachment 417565 View attachment 417566 View attachment 417567 View attachment 417568 View attachment 417569
I have three sub frames, one is for the early solid mount Chryslers as found in the 69 convertible 300, then I have one to suit a Plymouth, then lastly a big frame to suit a car with rubber isolators. Are you interested in one?Did you happen to save the front stub frame?
