For those it might interest, the Imp has arrived yesterday, (and has had me ditching my customers for two days now)..
"No.. no time, go away.. I have a new shiny object"
The 2 hour trip across Denmark was painless, sunshine, and the mood was the best possible, until about 300 meters from the shipper lot, where I decided to make a half mile short cut, crossing a SEEMINGLY dry field, which turned out to be a friggin SWAMP !
Arrived at the shippers with "squishy shoes", and spotted the Imp right away.. the 40 ft impression was really good, and both me and my Mopar thought that it very much like a vert, with the padded Imp-vinyl top.
As we came closer, came also some disappointments.. The imp was both scratched, and dented on the driver door, and passenger front fender, from poorly built wood scaffolding inside the container, plus the PS side front tire had been torn ½ way off the rim. A-Pillar molding had been crushed, probably by some moron, trying to push the 2,2 ton car. Also, several smaller fresh scratches around the car. The damages from the shipping is not overwhelmingly bad, but still annoying, and ruined what was otherwise a great day. Also, it is unacceptable as we agreed on a "first class transportation", and I even asked if they used their own (proff) staff, for packing the containers, which he confirmed. (plain old lies). Happy that I paid for a full insurance.
The third car, a (75?) red Corvette, jumped of the ramp one side, rubbing the front fender on the container side wall, and then.. suddenly, both ramps lost their grip on the scaffolding, and fell to the bottom of the container with an eerie sound. The Corvette received a "rear end uppercut" by the pallet of heavy duty shipping crates deepest in the back.. nearly tearing the rear end completely of. That poor corvette got a horrible first impression of Denmark... it was a bad day in the shipping insurance business.
The staff was busy apologizing to the Corvette-owners, and as I had nothing nice to add and just wanted to LEAVE ASAP, my friend and I solved tire issues ourselves, with he tools we found in the Imp, and a portable compressor.
The Imp was checked and topped for oil and water, and we paid for the transport, and rolled quietly out from the shippers lot.. only to reveal, that the car had had nearly NO brakes.. great ! Also, it had to crank through at least all 8 cylinders, before starting (weak fuel pump) ?
But it did start, and sounded fine, apart from running a little rough, so after lurking around the industrial area, getting used to the lousy brakes, we rolled onto the highway, heading home. 55 mph, and keeping good distance..
On the way home, the following was revealed..
Working:
Sound deadening works FINE in the Imperial. Wow man.. noticeable less noise than in any other Chrysler Corp car I have had..
Radio somewhat working, (picking up ONE FM station), and played through only ONE dash speaker.. speaker membrane sounded intact.. amazing :-D
Power antenna went SOME of the way up.. and in SOME positions, would agree to go SOME of the way down again :-D
2 of 4 dash flood lights worked..
Power bench worked some ways, but wired wrong (or "SOFA", as I think describes it better, in the Imp)
Heat worked, but only at the levels
"off", or "Tropical"
Cruise control worked, but cancel only worked by activating the brake pedal
PW switch area flood lighting and ignition light working incl delay
Sequential lights DS
Trunk light
Door light (No center roof dome in the Imp..?!?)
Head lights incl doors
Cornering lights (SHARK LIGHTS
NOT Working, or working "bad"
Suspected heater core leak, as dash and windshield was greasy, and car got foggy with windows rolled up
Intermittent jerky / uneven propulsion, and idle was bad too (I suspect again the fuel pump)
Sequential lights driver side
Driver side tail light FULL of water.. we are talking "aquarium style full".. made an amazing size puddle!
Map light
Of course, the A/C
Brakes (incl parking brake)
Front turn signals both sides
Announced Power locks = Lie
8-Track
After a controlled gear-box assisted braking at a bridge payment stall (3-to-2nd only), the box seemed to stay stuck in 2'nd for a mile or two.. (low on fluid?).
We checked that ample amounts of fluid was present, but not exactly following the correct level check procedure, as it seemed to work fine.
All the above was noted yesterday, but now, it gets a little worse..
When I started the car this morning, it started without "aid", after cranking about 10 seconds... But after another 10 seconds of idle, an annoying
"valve-lifter-like-clicking-sound" came on, to accompany the otherwise very quiet and smooth 440 sound.
Refusing the accept it's a bad valve lifter, I first loosened the generator, and stripped stuck the two "A/C & Generator belts" to exclude these exterior units, but the clicking did not originate from the generator or compressor. It was to cold and windy to do anything else, so for now I REALLY hope the sound is from the fuel pump. I seem to experience now the clicking has arrived, that "unassisted starting" is getting harder too, and now has much less chance ot starting without a "snaps" (as we Danes call the classic shot glass of gas poured in the carb). Anyways, I am not going cruising before I have the brakes fixed, and isolated that hell'ish clicking.
Trying to bleed the front brakes was completely futile.. rear chamber was empty at first inspection, and what I poured in there, never left the reservoir. The fluid was, or quickly became murky in both front and back reservoirs FAST.. and activating pedal produces a little geyser, but no fluid appears at the caliper. I suspect the master to be shot. Tomorrow, I hope to have time to see if a "vacuum bleeder" can suck out some rusty brake fluid, and achieve pressure to the front discs.
Of course this brake fix attempt is temporary. I am currently considering reworking, or new front calipers, new rear cylinders, master cylinder, power assist unit (functional now, but ugly as hell, and could break anytime). I can't find the discs new at Rock's, so I probably have to go to the rework place anyways.
A related question, or rather request for advice: I'm considering Raybestos hoses at 17,95$ over Dorman's priced at only 6,63$.. and also premium brake pads.. Any recommendations in this regard..? Is there any obvious advantages in buying the expensive parts, or a waste of money?
Cheers C-PPL's ;-)K
