1970FuryConv
HEADS INSTALL
· Used to clean Scott towels to wipe down the deck surfaces of the right side head and the right side block. I turned the block so that the right side bank of cylinders was vertical and the deck horizontal.
· Install Fel-Pro gasket on dowels with printed side facing up
· Head Bolts: I had organized 17 head bolts in a piece of cardboard. Clean them on a wire wheel, but keep them in order.
· Head: install on dowels. Inside corners of head match corners of block at intake
· Head Bolts RS, install: I followed the diagram to install the 17 head bolts FSM 9-49. Worked from the center outward. Torque 40 – 70 – 70 – 70 foot-pounds, 11/16 short socket, 6 inch extension, 3/8 to ½ adapter, ½ torque wrench. (11/16” ½” impact socket too fat to install around outer 8 bolts.)
· Head: LS, same procedure except I used grinding wheel on drill to chamfer top of dowel beside cylinder # 7. Must have hit it too hard when I hammered it in at Ben Tillman’s shop.
Torque Wrench
· Freeze Plugs, heads: 1 ¼" sides, 1” front and back. CRC Brake clean ports. Permatex #2 gasket sealant ports and edge of freeze plugs. 1 5/8 plug driver, pipe , and hammer to drive flush to side of block
· Broken spark plugs: plug SP holes for painting.
· Paint POR-15, 2 coats: heads, block directly below heads, top front and rear of block. Need to ditch Moto G7 Play Phone.
Torque Wrench
