1970 Fury III FS Appleton WI. Craigs
Pete Kaczmarski
Waupun WI.
found this tonight....
1970 Plymouth Fury III convertible
970 Plymouth Fury III convertible - $4500 (Greenleaf)
< image 1 of 15 >
18 automatic-power steering, manual drum brakes, air conditioning, runs-85,000 mi, carpet removed, floors and trunk solid, just surface rust, door panels off. Can look inside doors, older repaint, filler bubbling and cracking in lower parts of car, car is in heated shop and will be on a lift so you can inspect, delivery available locally. Call or text after 2:30 weekdays, any time weekends. Ony 1,952 produced!
Very similar to mine, not as clean underneath.The phone number doesn't work in the ad.Someone should try to get a photo of the tag.
Car looks like to be originally EF8 Ivy Green metallic, repainted in a dark teal. Am I dreaming, or do the front seats sport an incorrect black or charcoal paisley fabric? The rear F8 two-tone green bench seems original. Options: power steering and air conditioning, but also manual drum brakes and two-speed wipers.
The seller is a straight shooter. He readily sent me additional pics of the interior as well as a photo of the fender tag. Per the seller, this 'vert "runs and moves and stops, but needs carb rebuild (and)power steering leaks at the box; (she) hasn’t been registered since 2001 (and) needs to be looked at top to bottom."
The front bench is not original, but all the door panels are there (the fronts are off the doors) and neither the steering wheel nor the dash (remarkably IMHO) is cracked -- though some of the A/C vents seem missing. This car has several optional niceties (A01 lights, L31 fender repeaters, H51 A/C), which is perhaps a reflection of the T-code VON:
PM: Plymouth Fury iii
27: Convertible
G: 318 230HP 1-2BBL 8 CYL
0: 1970
D: Belvidere, IL, USA
143959: Sequence number
E44: 318 cid 2 barrel V8 230hp
D31: A904 3-Speed Auto Trans.
EF8: Dark Green Metallic (Dodge), Ivy Green Metallic (Plymouth) Exterior Color
M4F8: Trim - Opt. Decor Group, Vinyl Split Bench Seat, Green (Two-tone)
EF8: Dark Green Metallic (Dodge), Ivy Green Metallic (Plymouth) Int. Door Frames
A23: Build Date: October 23
T16148: Order number
V3W: White Convertible Top
A01: Light Package
G11: Tinted Glass (all)
H51: Air Conditioning with Heater
L31: Hood/Fender Mounted Turn Signals
M31: Belt Moldings
M85: Front & Rear Bumper Guards
R11: Radio Solid State AM (2 Watts)
V01: Mono Tone Paint Treatment
V5F: Body Side Stripes, Green
Y05: Build to USA Specs
26: 26in Radiator
END: End of Sales Codes
There are quite a few Fury 'vert for sale at the moment, this one deserves saving as well. Paging @Mr onetwo, @DeltaV, @Yeahrightgreer, @cuda hunter, @FK3 Sport Fury, @shooter65, @rags ...
< image 1 of 15 >
I bought this car and had it shipped to Washington State. Still runs and drives great. I will restore it.
