You are making a lot of progress and your detailed photos and descriptions of what you did will help a lot of people out. I am so glad to see that restoration of the sister to my car is progressing.
I get your point, thanks.You are making a lot of progress and your detailed photos and descriptions of what you did will help a lot of people out. I am so glad to see that restoration of the sister to my car is progressing.
Empty your inbox, please.Kudos to you, major endeavor, my little restoration is nothing compared to what you will do to bring her back, you are a skilled man, all the best!
PT
You know, Jim, I copied that picture months ago when I was trying to figure out whether to replace or repair the subframe. I completely forgot where I copied that picture. I'll edit to give you credit.Hey, I recognize that ridged stub frame!
Nice work Ben, progress is motivating. Word of advice, replace the fuel line through the frame before you reinstall in the car! I saved a number of my smaller brake lines as well, but the fuel lines were junk.
Haha, no problem take all the pics you want, that’s why I post them.You know, Jim, I copied that picture months ago when I was trying to figure out whether to replace or repair the subframe. I completely forgot where I copied that picture. I'll edit to give you credit.
I also like your spell check and a ridged subframe. New Mopar terminology!
I agree about the fuel lines and the brake lines. Thanks! Ben
emptyEmpty your inbox, please.
Thanks, Steve.Personally I believe it is wise to replace brake lines that old even if they look OK from the outside. Brake fluid is hygroscopic, meaning it absorb moisture from the outside air and over time causes rust to occur inside the lines that isn't seen by looking at the lines externally - i.e. they might rust from the inside and surprise you at the worst possible time.
Not a purist either. Ni-Cop is a great option, especially since original engine block was cracked and removed in the 1970s. Originality is not a big concern for things like brake lines.I'm not a purist so when I replaced all of the lines on my car I used ni-cop. It is a dream to work with.
