That would be much appreciated. I have contacted Murray Park but that may not pan out.I recently replaced cables on my Polara. Exact reproductions. Let me know if you need the info.
See here -- Evans Wiring did an outstanding job, and others have had similar experiences: Evans wiring Engine Wiring HarnessThat would be much appreciated.
Shot an email off, going to see if they can do something for the Imperials too.See here -- Evans Wiring did an outstanding job, and others have had similar experiences: Evans wiring Engine Wiring Harness
I met with John Evans at Moparfest this summer. He had a look at the Imperial positive cable and said it could be made, just that the relay/fusable wire bullet connector will have to be the square Packard style spade connector.Shot an email off, going to see if they can do something for the Imperials too.
Can you post a pic of that cable?See here -- Evans Wiring did an outstanding job, and others have had similar experiences: Evans wiring Engine Wiring Harness
@71Polara383 can confirm that this is the Evans cable after installation in Snow White, my N-code 1970 Polara 'vert:Can you post a pic of that cable?
How is the wire gauge? up to original?@71Polara383 can confirm that this is the Evans cable after installation in Snow White, my N-code 1970 Polar 'vert:
Yes it is. Very happy with it overall. Looks perfect.@71Polara383 can confirm that this is the Evans cable after installation in Snow White, my N-code 1970 Polar 'vert:
I have seen his work on FB if I recall. Probably a good fella to work with as well.I use Joe White for distributors, but I am looking for a good carb guy.
