NOT MINE 1974 Chrysler Imperial LeBaron 2dr Hardtop - $4,900 - Nesconset, L.I.N.Y.
marty mopar
Feedback: 9 / 0 / 0
For Sale: 1974 Chrysler Imperial LeBaron 2dr Hardtop - $4,900 - Nesconset, L.I.N.Y
1974 Chrysler Imperial Brougham - cars & trucks - by owner - vehicle... (craigslist.org)
Seller's Description:
1974 Chrysler Imperial Brougham V8 440 2dr hdtp, white inside and out , for sale powerful big 7.2 litter engine per original owner daughter they ran last year, oil and fluids look good, may start with a charge, or not, very low original 45k miles. Amazing clean white interior, straight body little rust spots. $4,900.
Contact: no phone listed.
Copy and paste in your email: bd956298516a306891eb0c0d7ec4fbf7@sale.craigslist.org
What a beauty.
For posterity. CL ads disappear after a time. Looks like two different times (different WHITE cars??) .. clean car, some dirty car, some with road wheels, some with hub caps and new tires??.
Also has green '77 Imperial (??) for sale in same ad (1 pic)
Seller Description:
"1974 Chrysler Imperial Brougham V8 440 2 d sd white inside and out , for sale powerful big 7.2 litter engine per original owner daughter they ran last year, oil and fluids look good, may start with a charge, or not, very low original 45k miles $4900 Amazing clean white interior, straight body little rust spots."
Seller Description:
How do I get in touch with the owner
That white two door add is an add from a few years ago.... A Jim Gesswein car I believe, so beware of the white '74! The other one or two, whatever it is, I tried to contact the owner.... Nothing, no response!
something odd going on with this ad.
Here is the nicer white car .. in a SD ad. exactly the same pics. re-used and NOT disclosed as an example of the dirty car which itself does NOT look like a '74 Imp (it doesnt even have waterfall grille).
For Sale: 1974 Chrysler Imperial in Milbank, South Dakota
all that, and perhaps hard to contact seller?
Yep! The white 74 Imp coupe used to be my car, over 20 years ago! It is a sunroof car. Was not Gessweins originally. Car came from Cedar Falls, Iowa, guy named Fridley. There were only 57 Imps in 74 that had the crown roof, which is same as the later St. Regis roof.
The limited run cars you are referring too are Crown Coupes. In '74 they were all a beige-y gold dark parchment-y color. Very 70's. (Also shag carpet-if you are into that sort of thing). It was a 50th anniversary trim package
Here is a sample of the crown coupe
Finally an Imperial without the St. Regis roof.
The back-and-forth about the Crown Coupe in a thread about a 1974 non-Crown Coupe Imperial was started off by the quote above.
That quote is more applicable to the 1975 model year, when the Crown Coupe production numbers exceeded the normal 2-door Imperials, at least, according to this site:
Imperial LeBaron 2-Door Coupe $8,698 Weight: 5105 Built: 1,087
Imperial Crown Coupe $9,277 Weight: 5205 Built: 1,641
Scam …. Or deal of the century !
I put my money on scam .
Then you got a screaming deal !
I would pay that just to use it as transportation.
Keep us informed
