1976 New Yorker replacement radiator
76 New Yorker
Plant Earth
Hello Folks,
I need to find a replacement radiator for the 76 New Yorker. (440 / 727) It seems all the aluminum ones are the small size. 18 3/4" X 27 5/8". Not the 19 3/4" X 27 5/8". The 18-inch ones have a different mount bracket bolt hole location. Then being an inch shorter in the core, the shroud will not fit. Are there any correct replacements out there that you are aware of?
Thanks
Hello Folks,
Thanks
You can have your existing radiator re-cored at any good radiator shop. To do this, it will cost about $800 but it will be correct when you are done.
