which I am doing.
However...what's intriguing is the 999 interior code. Typically, you would see another color code. Here's another 77 PK41 car with A1B3 interior but with PB3 code following. (also notice the B "for sale in Canada" supersedes the K "cop car" VON.)
FK3, as you look at the car, see if you can find the vendor tag attached to the bottom frame of the seat. It's about .75 high and a couple of inches long. There should be some info on there that could be interesting.
I don't have the car at my place so it might be several days until I'm back there again but I'll do that when I can.We're expecting several days of rain starting tonight so it won't be real soon.
Also,the floor pan on the passenger side is so rusty that the only thing holding the back end of the seat in place is the floor mat.I'm sure I could pull that seat out without having to unbolt it but would probably rip the floor mat even more.
Is is a metal tag? and do you know where I should look for it on the seat frame?
Here's one more look at the drivers seat,in this one you can see the pattern of the fabric.It looks like a standard Mopar fabric but I'm not an expert on cars in the formal years.
which I am doing.
Point of interest.
From scanning the Hamtramck Registry library, it appears thatall the buckets were highback and the benches had those "brick" headrests.
The seats in question are regular back buckets with headrests.
Example:
I need to go back to the earlier seventies I think to find buckets with headrests.
Thank you, sir.I do believe Es and B' s went to high back in 70 and Cs went in 71
Thank you, sir.
I am working with the most miniscule details here. All I have to go on is the headrest and a tiny portion of the seatback hinge. The aftermarket seat cover obscures the original pattern.
I've gone back to 1969 and I still can't find a factory bucket that matches this seat. I'm gonna be a real pain in the *** and ask for a pic of the seat w/o the cheap seat cover. Thanks.
Very bad, cars of these years were rot boxes made out of very low grade metal.
