1978 NYB New Engine.....
Interesting decision. I fully understand the desire for a "drop-in" situation.
As I suspect they'll be searching for a buildable core, you might need to look at your accessory mountings on the existing engine to ensure that they get a core with the same attachments. I know this sounds "not needed, they're all the same", BUT a few years ago, a customized Sierra wagon came through our shop. It had developed a lower engine knock, so an "engine" was procured from an unknown source. Same 440 displacement, but the accessory mounts were all different, which also included a few which needed a matching casting difference to work.
So, they might need the casting number and date from your existing engine so they can look for a matching-casting block. I'm not sure when the castings might have changed, but from what I saw, they did.
Congrats and good luck!
Sierra? Same 440 displacement,
I will take issue with this. Unless it's a industrial/marine block, once the water pump housing is removed, the 66-78 440 bare block should be the same as far as mounting any external components.
And I would think the same for the 400.
Sierra as in '56 Dodge 2-dr station wagon. It was a customized and modified car that came from a B-J auction a few years ago.
There WAS an added casting bulge that had a bolt hole in it for a mounting brace. Not sure of the vintages of the two block, but there WAS a difference which required some salvage yard time to correct. I saw it with my own eyes as we all figured "they're all the same", as the tech pointed it out to me after he tried to swap out the existing accessories. The new engine didn't have it.
1978 NYB, please note Commando1's solution for casting bulges where might exist. Not sure what the solution might be for the resulting un-anchored bracket might be.
I mentioned that issue as it was something I'd never seen before OR suspected might happen. In the hope that a matching casting number/similar date might ensure you got a block that would truly be a "drop-in" situation.
Respectfully,
Let's not get to hasty here. I don't think you should shelve that idea this early in the game. I see the house above already has a garage. With a few modifications and the right girls, this engine swap is paid for.
Seriously though, the power increase will be nice. Are you doing any other drive line changes?
No, this is purely a cruiser. Transmission and rear axle are good to go. It will have a little more power than a stock 69 big block RR.
1978 NYB, please note Commando1's solution for casting bulges where might exist. Not sure what the solution might be for the resulting in-anchored bracket might be.
Respectfully,
Carolina Machine Engines assured me that it is a drop in with no problems. Even with aluminum cylinder heads.
I looked at those guys when I first got the Polara (I was thinking of my Dart) and they seemed like the best choice. Called them up and asked all the stupid questions a newbie would ask and they were very polite and helpful with my Stoopid self. Being under paid and not a saver, that plan never came to fruition.
I found them very courteous and informative. The initial contact was a great experience from a customers viewpoint. The only disappointing point was 12-15 week build time. With 100 engines ahead of mine says something about this engine builder. All good!
Free delivery to Carlisle...
I'm hoping to have the new engine and finish installation by then. If that happens, I have no problem bringing the old engine to Carlisle in my Truck and heading back home to get my NYB.
You don't have to do that but if it is out I can settle up with you or get it etc.
They have remanufactured 50,000 Mopar engines since 1984.
There is 100 engine orders ahead of me causing the wait time.
Somethings not adding up on the match here... 50,000 engines over 34 years comes to an average of 4 engines per day, and that is if they work seven days a week (and only do Mopar). If there are 100 engines on order ahead of yours, that’d be about a 7 day queue until they get to you. Now I don’t have a dog in this fight, but it might not hurt to call them back and reminder them of their own claims and how it pans out mathematically. Just say’n.
Moot point, isn't it? You could argue mathematically all day with them but I'm sure their reply will still be 12-15 weeks, take it or leave it.
I don't think that insignificant point is something that I want to call and argue about BEFORE they build my engine. The bottom line is.....who cares? I sure as hell don't care if they build 4 or 20 engines a day. I'm only concerned about the one they are building for me.
They wouldn't have an A+ rating from the BBB if they were a sub-standard engine builder.
Congrats Bob!! Look forward to seeing this happen. I know you’ve been talking about it for a while now.
I'm going to go all out on this build. New everything.
Where can I get motor mounts from?
I recommend these guys, with the poly mounts. I installed a conversion set of mounts from them into the monaco with the 440. Was very pleased with them, and they bolted up right in place.
Schumacher Creative Services
I remember reading that Chrysler claimed they could grunt out a 331 Hemi every minute, back in the day. So 4 a day wouldn't be that much of a problem.
If you've got a team of let's say 15 employees/machinists, and everyone is well crafted at their job, all in sync and well orchestrated, new parts, blocks cleaned and prepped etc. I don't see that as a problem. How many does say, Jaspar build a day?
From what I've read they seem like a great company.
I worked St a parts store with 3 guys in the shop, mostly heads and more heads. We did full rebuilds, but not our bread and butter. I only remember delivering a few engines, but delivering a ton of cylinder heads. The engines generally weren't in the shop for more than a week or two. Can't remember if each tech stayed with it the whole way through or not. Later when it was a one man shop, they did whatever they wanted, one guy took forever, the next guy banged them out so fast you wondered if he knew what he was doing, he didn't and I called him out all the time! The last guy I worked with gave me one of the engines built by Speedy, and later told Loss Prevention I stole it! Then when dropping it off, says he had nothing to do with it. He knew and I knew, guess the nice in the store called? My time was done anyways, but it would have been nice to leave the way I should have, telling the new manager he was an idiot! That guy got fired later for working on his own stuff while on the clock. Karma's a *****, Joe!
I think Bob's going to be fine with the folks he chose.
