NOT MINE 1979 Magnum $5500 _ Downers Grove IL
GregG48203
Detroit MI
Not Mine; I'm only posting this because the Servprolara is in the background.
1979 Dodge Magnum · Xe
1979 Dodge magnum XE $5,500
Listed 3 weeks ago in Downers Grove, IL
About this vehicle
Driven 94,000 miles
Seller's description
1979 Dodge Magnum xe factory black and e58 3604bl 727 9.25 3:23 sure grip. Factory tach needs to be hooked up. Has a 74 360 that's fresh in it. I also have the original 360 that came with it. Has Mallory comp9000 distributor (no lean burn) and flow kooler water pump.Just completed hot rod power tour with it new alternator/ fuel pump and tires runs and drives great. brake booster does have a vacuum leak and wipers need a bushing to work properly.
This was from the last leg of the PowerTour. My buddy Bubba and I blasted back to Chicago together after a rainy day in Norwalk.
