Triple Pickle
If you want to talk surviving in a crash, don’t kid yourself. Today’s vehicles are safer than ANY vehicle from the past. That is an irrefutable fact.
Well beside the engineering problems my main concern is my daughter in a tiny tin can car that weights between 2200 to 2400 lbs up against today's cars that are 3000 and up..then the idiots in 5 to 6000 pound suv's, pickups who's bumpers are at the middle of the driver's door glass.
The van would be interesting. I had an 89 Voyager turbo van that I rebuilt the engine and removed the balance shafts and had balanced ,bigger turbo and added an intercooler. That was a hoot!
I had a '87 Omni. Damn thing was like a mountain goat! Tires - $25 a piece at Sears.The engineering problems aside, you folks get serious snow, what about ground clearance? A car with 3" free space underneath is not going to get very far in 6" or more of snow.
Non-occupants involved in vehicle crashes usually don’t fair well no matter what year the car was made.Tell that to Anton Yelchin.
I can know in about 30 seconds weather my old car is tow truck terminal or just a quick fix. When a new one dies on the side of the road, then what?New ones and old ones don’t compare?
They don’t
Sounds like another way of saying old and new don’t compare! All of them can give you trouble sometimes is the only constant. Diagnosing what in the world is wrong with the newer ones isn’t fun for sure!I can know in about 30 seconds weather my old car is tow truck terminal or just a quick fix. When a new one dies on the side of the road, then what?
My BIL and sister have a mini van right now they bought as a extra /work vehicle. Most days it will not start because the fuel pump will not turn on, no check engine no melted wires, changed the fuel pump (that is as far as we went with shotgunning parts,) we did swap around the relays. It's been to a few known good mechanics, they are all pointing to the board in the fuse box but can't say for sure. A $1200 guess and that's just the part. If my fuel pump stops working on my '68 Charger, I know I'm not buying a fuse box. That's all I was disagreeing with. Yes they work well, but if they have a problem that is not consistent all the time they are way worse than a old car. We ended up building a parallel system to feed the fuel pump, of course the auto shutdown does not work as it should if something happens.
I had an 85 Omni I bought new and drove almost 200k. It was overall quite dependable and very good in snow, but did have to change the head gasket around 100k. I see you'r in Canada, be careful of rust on these, bumper brackets, frame and fuel and brake lines seem to be prone. Also, if the door hinges wear out, as I recall these were welded in to the body and hard to change. However, might want to move the date range to the 90's and up, airbags were standard by then and ABS was a popular option.
Lots of crash protection was added to cars during the 90's. It all added weight, which partially explains some of the weight differences between then and now. Extra steel used for side impact protection and such, for the most part better crumple zones, etc. The addition ABS is a + and a -... yes it will make stopping more controllable, but it also provides another expensive point of failure. The number of shops equipped to work on a system that old is dwindling too.If you want to talk surviving in a crash, don’t kid yourself. Today’s vehicles are safer than ANY vehicle from the past. That is an irrefutable fact.
I have posted this before but here goes again. Same getrag 5 speed 9 second fwd Omni glh.
Omni GLH Dyno 577hp 552 ft-lb
says 8 valve 2.2 turbo
Not bad for 135 cubic inches ,,,,
I witnessed a distracted (cell phone) driver in a Windstar hit a friend of mine in a 80s S10 head on about 45 mph.Something brand new, with all the safety gadgetry would be ideal if you keep her bubble wrapped... but don't get her wet and never, ever feed her after midnight... kids do stuff and accidents happen, would you feel better if she just used public transportation and uber to get around?
Soundz like you drive in ah hazardous area? MOOSE, COW, PIG, HORSE YES AND BAMBIE TOO. THEY'RE ALL GONNA HURT YEAH IF YOU ARGUE WITH AND CONTACT THEM AT SPEED. Run (SR212 the back door from Rapid city to Billings) in stead of I-90 all the way around and save 65 milez, but be aware the the the Native Americans have been known to wait 'til after dark and deliberately run their cowz 'n horses out in front of you if you try and run thru' those little villages on the reservation too fast (open range you know). It'll give you a new appreciation for what they did to Custer over on the other side of the hill on I-90, JerI’ve hit deer in several different vehicles including a ‘68 Barracuda, ‘87 Crown Vic, ‘78 Bronco and, a few 88-98 Chevy trucks. The Cuda took the most damage but limped home. Unlike trees or other vehicles, big critters can do some damage but usually they have a little give to them unless it’s a moose or cow. I’d rather hit a immovable object in air bag, crumple zone equipped Kia than I would my old 72 Polara!
