No option for anything other than a black steel wheel with the H-70 tire.Was there an option for a Hurst Road Wheel for a spare, or did all Hursts get this wheel for a spare?
It's the standard spare wheel for any '70 300, from what I've seen. Had the same wheel in my coupe, and I've seen it in many a survivor trunk from 'vert to 4-door.So this wheel was standard in every Hurst?
Meaning, this type of wheel should always be saved for a Hurst guy?
Did someone say "trunk"?It's the standard spare wheel for any '70 300, from what I've seen. Had the same wheel in my coupe, and I've seen it in many a survivor trunk from 'vert to 4-door.
I wasn't clear - I knew the dolled-up Road Wheel was standard for the Hurst - I meant that any wheel of this type should be saved because it's the only wheel correct for a spare for a Hurst.No, it's just a standard 15x6JJ wheel that has other applications.
The "Hurst Wheel" is the chromed, slotted "road wheel" with the body-match paint and the pinstripes.
So on the cars you've seen, were they Road Wheel cars or wheelcovers? Either type?It's the standard spare wheel for any '70 300, from what I've seen. Had the same wheel in my coupe, and I've seen it in many a survivor trunk from 'vert to 4-door.
Does that bowling ball bag have the correct date code on it?Did someone say "trunk"?
As soon as I hit ”post” I realized what was coming….
just a couple of examples, my coupe has road wheels:So on the cars you've seen, were they Road Wheel cars or wheelcovers? Either type?
Was this wheel used on the car also if it had wheelcovers? Or just as the spare?
I ask only because I saw one years ago, knew it was special, but it took years to learn they were used on some (all?) wagons.
So I'm just trying to learn more.
You know when you least expect it a surprise rebuttal is coming, stay tuned!
Nice…but the wing support is not correct. It’s not the factory part. The tips aren’t correct either. ;)I took this pic of a Hurst that had just changed hands at Carlisle 2018, don't know the price. I guess this wing had "the sags" long ago.
Notice it has the dual-tips, too.
I don't know if I've ever really seen correct tips, except in 1970 promo pics, so I certainly believe you. But these were the most "normal" tips I've seen, and we've all seen some silly exaggerations out there, almost like this:Nice…but the wing support is not correct. It’s not the factory part. The tips aren’t correct either. ;)
