To re-cap:
318 poly in my '67 Monaco was replaced in 1986 by reman LA318 bought from the same chrysler dealership where the car was originally bought from. I had to acquire oil pan, rocker covers, exhaust manifolds and possibly intake manifold, distributor and carb to complete this engine swap.
I put about 10k miles on the car from that time up until maybe 1995, car was in storage from 1999 and only last year did I fire it up for a few miles of driving before it went back into storage until a month ago. I don't recollect if it idled well or not back then, I'm assuming it did.
Current issue - it doesn't idle well. Very rough. Carter 2-bbl carb.
Warm (not hot) compression test came up with 142 - 152 PSI numbers.
I've taken the carb apart, throttle plate shaft has hardly any play, very clean inside. I've set the mixture screws 2 turns out and then have tried to set them to give best vacuum, turned them out an extra 1 or 2 turns, but vac needle bounces around too much to see any difference. I'm doing this with RPM set to 600-650. Vac bounces between 12 - 15.
Engine does not hesitate and responds instantly to opening the throttle either slowly or quickly. Runs better at 1000 and much better at 1500 rpm. Vac reads steady 20 but I should verify that.
I've disconnected the vac line to the brake booster and plugged it. No change. Choke pull-off works very quickly and strongly immediately after engine is started.
Prior to starting it for the first time in 20+ years, I changed the oil, squirted oil into the cylinders, cranked it by hand a few turns, put in new plugs (Champ RN14YC).
Taking the PVC valve out of the rocker cover and blocking the valve with my thumb, I feel vacuum, engine doesn't like it, rpm's drop a little.
A few days ago I put in new points / condensor / rotor / ballast resistor. Did not touch the cap or wires. No difference. Set the gap to 17 thou. Did not remove the distributor when changing parts. I could (or need to) check dwell and timing, need to get timing gun and meter. I bought a cheap little battery-powered digital RPM / hour meter, it has a wire you wrap a few turns around a plug wire to sense RPM. Very slow response time, but it does show RPM, that's what I'm using to set idle rpm. I'm assuming it's accurate.
I will aim at doing a leakdown test next.
What is on my mind is this:
- acquire new timing gear/chain set for future install (will include chain tensioner)
- change to electronic ignition
- how to determine if I have a valve or valve-spring issue?
Has the gasoline changed that much in the past 25 years? I'm using el-cheapo 87 octane gas here. Best we have here in Ontario is 91 octane if that's an issue.
I know it really looks like it's a carb issue, but I want to know if something more serious valve-wise or timing chain is going on.
Does carb float level play a huge role here in idle stability? I have a bit of gas weeping through the airhorn gasket, I should look into that, maybe check the castings for flatness.
Maybe the distributor has too much play? Worn lobes?
No easy way to look at timing chain without draining coolant / removing water pump?
Thoughts?
Thoughts?
