Oct 26, 2017 #1 Dodgy Dick Active Member Joined Mar 13, 2016 Messages 254 Reaction score 128 Location Queensland, Australia How do you tell if a 340 crank is Cast Iron or Steel? TKS
Oct 26, 2017 #2 max1196 Member Joined Sep 21, 2016 Messages 143 Reaction score 72 Location Swift Current Saskatchewan The parting line that is created from the "molding" on a Cast crank is about 1/16 inch wide where as the Steel crank has about a 5/8 inch wide pattern.
Oct 26, 2017 #3 B barnfind Old Man with a Hat Joined Nov 20, 2014 Messages 6,018 Reaction score 9,332 Location Around Town This is a 440 but shows the difference between the 2 types.
Oct 26, 2017 #4 D Davea Lux Old Man with a Hat FCBO Gold Member Joined Mar 27, 2017 Messages 9,387 Reaction score 8,849 Location Cornelius Or You can also tap it with a tool on the parting line or some where else that is not a bearing surface. The steel crank will ring. Dave
