has2bmopar
Good examples has2b! Thanks! One question though, what's bad about a 4" stroke on a 4.030 bore as far as stroke to bore ratio goes?
The bore diameter plays no part in it. The rod ratio is what comes into play. It is your deck height, which is the measurement from the crankshaft centerline to the deck surfaces of your block vs the stroke and rod length. (Room to move for your rod and piston assembly).
