383 Rough Idle Stops WITH Vacuum Leak. Huh?
Top on is vacuum advance. Also if your throttle (butterfly) is too far open you will get too much vacuum to distributor.
It usually means that you may be too lean and are compensating by opening the butterfly with your idle screw
