Rusty Muffler
Hi all, been a while since I sold my 66 Fury, but have recently acquired a 57 Plymouth Belvedere 4 door sedan. The 301 engine has been rebuilt and is out of the car. I bought the car this way with all the parts and bolts in the trunk. The trans was not removed, just supported at the front. I see the main frame crossmember where I assume the engine mounts go. After some reading I see mention of a rear engine cross member? I can see no evidence of that. Also the torque converter has 8 threaded studs coming out of it in a circle that mate with holes on the rear of the crankshaft. There's also a 1" thick horseshoe shaped spacer that goes between the engine and transmission. Question here is, how did they get to these studs to install the nuts? The MOTORS manual says to remove the engine you have to remove both engine and transmission. This is obviously not the case. What am I missing here? In the bell housing picture you can see a little slot at the bottom for access?
Also, is this car a Positive ground or Negative ground? Thanks!!
e
und?
