64 Crown Coupe parting
Right now the car is on 2 flat rear tires so the doors won't clear the car trailer. I will try to jack it up tomorrow am when it's not 110. Will get pictures of the sill plates then.
Glad I am not in a Hurry.
Back in town, need to get the car off trailer the start pulling it apart.
I jumped the motors with 12 volts none work. Good for cores I guess?
Did you ground the body of the motor and touch positive to either wire? It wont work if you simply hook negative to one wire and postive to the other. Clamp a battery charger cable to the body of the motor and turn it up to 25 amp or more. Touch the positive to either wire and it should move. If nothing then yeah the internal circuit breakers are burnt out.
