SF-66TC
Couple pics of the La Chrysler 66 300 (Canadian built).
cbarge, SWEET!, but you still using a "single master"?
Took two summers to get her running,now I need another to stop her,LOL!cbarge, SWEET!, but you still using a "single master"?
Disc brakes coming up this summer.
Steven, As a process of elimination...
Jam a set of points in and run it.
In theory. if the weights are "stuck" it should still ping--even with points.
If no ping,then the dwell in the Pertronix may be a tad aggressive.
If you prefer to run your distributor,do a re-curve on it seeing that you have to take it apart to free up the weights anyways.
If you have to swap out dizzys...
My personal preference is the Summit Racing electronic conversion kit. #850004
The distributor in that kit has the perfect curve for today's gas and comes with an orange box,and wiring for under 200. bux
Hope this helps.
I haven't installed the pertronix igniter II I initially got. I wanted to diagnose the ignition problem b4 installing it otherwise I'd be running in circles. Since I believe the vac advance diaphragm was leaking and now that I found the weights are binding I'm going to swap out my dizzy for that 850004 from Summit. In a prior post I mentioned I was going to install a Proform, but I meant the 850004 as you suggested. The proform and Summit look the same (since it looked the same & it may well be..dunno for sure). Btw, the 850004 comes with the Blue box (already ordered), the 850003 comes with the Orange, but isn't for a 383.
Oh,crap...I forgot about that.It is important to put back the insulation wrapped in tin foil.
I just wrap pink insulation in tinfoil. Main purpose is blocking the heat from intake...and reducing noise,lol.Has anyone made up the tin foil insulation wrap? Just some fiberglass & tin foil to reduce tappet noise... correct?
For some reason my 850004 kit came with an orange box for my 68 383..Hhmmm..I am assuming they were out of blue boxes when I placed my order just before Christmas. No matter since the curve in the dizzy is more important.I haven't installed the pertronix igniter II I initially got. I wanted to diagnose the ignition problem b4 installing it otherwise I'd be running in circles. Since I believe the vac advance diaphragm was leaking and now that I found the weights are binding I'm going to swap out my dizzy for that 850004 from Summit. In a prior post I mentioned I was going to install a Proform, but I meant the 850004 as you suggested. The proform and Summit look the same (they may just as well be..dunno for sure), but the Proform is $50 less.
Kewl! For 25 bux,I will make my own,and when the job is done,buy a case of beer and enjoy the fruits of my labour,LOL!!You can make one yourself very cheaply, but this is where I bought mine for $25. There is some other cool stuff on their site too. Big Block Intake Manifold Insulation Dodge Plymouth Mopar
66tc - I dunno how cold it is out in san Francisco, but here in dfw I only need the choke when cold starting it from an overnight sit or whatever. if you do a manual choke on a wire its cheap to do.
Are you running the original single field alternator?? or newer dual field?cbarge, I got my 850004 this morning and I got the orange box too!
You got any install tips or is it just 'plug 'n play'?
The kit would work better with the modern dual field style.
Having good ground for the ECU is the key.
As for installation,for years the web lots of diagrams to refer to for install and in the kit itself.
No tricks there. .
Correct.Pretty straight forward.
Power from Blue wire when key is turned on.
