66 throttle cable
66furywagon
indiana
66 fury my throttle cable
Its unhooked at the carb.
And pedal.
Do i need to unbolt from the firewall.
Or does the cable just push through
The fire wall.
There's supposed to be an E-clip on the end where it goes through the firewall (on the inside).
And it will disappear into/under the carpet very readily when removed. AMHIK
What he said, for both sentences.
That clip is off and i did not loose it
Lol
I hooked it to the carb, then to the pedal, so it had tension when the ball went into the socket
