That's Ok. I was speaking from personal experience on many Mopars I rewired including both 68 Chryslers.Hello,
I have to respectfully disagree with cbarge on this one. What you did is absolutely the correct thing because if your car has the same problem as my 67 and you didn't look at the ammeter, eventually you would be doing the job again when the ammeter totally failed and shorted the connection post to the metal dash board frame. note the pics above showing the melted ammeter connection. I have 2 suggestions for you. Check the big black wire from the alternator step by step through the bulkhead connector in the same way you did the red one from the battery. If its good there follow it through and under the dash until it gets to the ammeter. along that wire all the accessories connect like the headlights, fan, power windows and seats etc.
On the ballast resistor if you are using an OE style coil, you should not have 12v on it. When the key is in the on position you should have less than 12v on the coil and the ballast resistor will get very warm if you happen to have the key on and the points are closed. This is normal and why the ballast resistor is made of ceramic material and mounted to metal so the heat can dissipate. There is only battery voltage on the coii while the starter is cranking since during cranking it is likely the battery voltage is below 12v. This is why there is 2 wires on the distributer side of the ballast resistor.
Incredibly coincidence that I just did this same exercise on my 67 in the past week. In my case the fuse box is bad. Even though the fuses are good, the clips are rusted enough that no current will pass.
Hope this helps.
Steve
Hello,
Another thing to check is the AMMETER. The Ammeter is in series with the battery feed to most of the car with the possible exception of the power windows. This will cause nothing in the car to work if it is bad and is a very common problem with 60's Chryslers. On my 67, there is a red and black wire connected to the ammeter. Both wires should have 12 volts to ground on them with the key off. I'm guessing only your red wire will. If I am right, the fix is to disconnect the battery, then disconnect both the red and black wires from the ammeter and connect them together with a bolt and nut (10-32 is best size) and a good tape job with electrical tape. Make 100% sure this splice cannot touch ground in any way when you are done. Once you do this the ammeter will no longer work, but the car will, so you might want to get a new volt meter to install in the car to monitor the charging system. I just this week fixed this problem in my car.
