68 fury iii distributor rotor
stu’s68furyiiirat
Kingsport tn
68 fury 318 distributor is in time I believe the rotor is pulling in the very back at 5 or 7 I’m trying to get it into 0° top dead center pull the distributor out and said it back. It’s always back at five or seven. The rotor is not pointing at one. Any help would be greatly appreciated.
The crankshaft makes 2 full rotations for each rotation of the distributor.
Rotate the crank 1 turn to TDC and it should line up.
Prob the oil pimp drive was not indexed right. Re position it or just switch the wires so one is where the rotor is.
