69 300 Manual Window Conversion
mrmopar66
Does anyone know if I can simply remove my power window regulators and install manual regulators? I was hoping there will be bolt holes in the sheet metal to bolt the manual regulators to?
Cool man, Thanks for the info. Im going for a different look for my 300. It did not have an interior, it might as well not. The seat frames were rotted bad and the door panels were non existent. Both rear window motors are missing. Im buying a 69 Fury parts car that has manual windows so I plan on using those.
Im going for a "stripper" 300 that hey never made.
Chase down one of the 1st two 300 Hursts produced and really make the so called expertz scratch their headz when they polk 'um in the window for ah look around and see the crank handlez
Maybe, Kinda, I never thought of it that way. Im gonna change this one up quite a bit in the interior. What it came with was beyond using so its kind of a clean slate. Im going with a Fury dash and losing the tilt and tele. I have the parts for a 4 speed set up now. I have even considered a bench seat. The outside will stay as it is.
So you mean Newport....
