First of all would this fit a 1972 Fury III, I presumed it did and was told it did so I purchased it. it is 47.30 between axles. Any issues with length of axles on Fury v Imperial
I am interested in rebuilding my 9 1/4 rearend, purchased without testing and not sure if works well - I was thinking about the Yukon Diff with seals here is someone installing one. I have a 8 3/4 with 2.72 now (one wheel wonder). New motor is around 500 hp and I want to upgrade to limited slip
Is this difficult, this guy makes it look easy but many special bearing tools etc.
With respect to the brakes. There are good rotors and new calipers on the axle now.
I know replacement 1974-5 parts are hard to find (rear rotors) Not sure if worth using or replace - is there a set of new brakes, that would fit the axle?
Thanks
Thanks
