After the other crack checks are found to be O.K. have couple .000s shaved to make sure the headz are flat. And another couple .000s to have the same knowledge on both deck's and you're good to go for the rebuild. AH SHORT TAIL AND LEARNING EXPERIENCE ON TRYING TO CUT CORNERZ ON A REBUILD WHICH WAS NOT MY INTENT... In '06 I had ah guy that came highly recommended with 30 yearz experience rebuild a well seasoned '67 Imperial block(sorry Matt) and told him to shave ah couple .000s off the headz and straight edge the decks and if they were flat leave them alone and carry on with the rebuild and he did just that. Problem waz and I never knew that he never removed the head locating pins when he did the straight edge treatment so when he got to that point he just jumped the pinz and continued on. Completely missing a low spot in front of the front pin on the left bank and another low spot in the bridge between #3 and #5 so bad move on his part that built me an A$$ kickin' 440 POS that I got ah whole 13 hours on beyond ah half hour break in before It started blowin' white smoke. And yeah know what? After almost a year of bickering back and forth with this dude I ate the 5K+ cost of the rebuild and moved on. That's when I found Eric of Muscle Motors up in Lansing, Michigan and we became and are still good friendz. Fortunately I had a 2nd. '67 Imperial block(sorry X2 Matt) to do it right the 2nd. time AND FORTUNATELY AGAIN MOST PIECES TRANSFERRED OVER AFTER SOME LINE BORING AND AH FEW NEW BEARINGZ. Because that 1st. 440 when the head gasket blew, #5 filled up with antifreeze so fast that it took out that TRW flat top and put chunks of it and the ringz in between the piston and the wall on #5 and cracked the block before I could get it stopped. I'm done! Your call on what you do for a rebuild, Jer
