Additive to fix Torqeflite shudder?
Id say no. It's hard for us to understand how severe of a vibration you are chasing. I have a 64 with a ball and trunion setup. It had a worrisome vibration at higher speeds that turned out to be too much grease in the boot, most likely all in one side from sitting on a hot day?? All went away....id be pissed if i tore the car apart for nothing.
Also, you mentioned an engine miss...i would track that down if i were you.
I think I made that better by installing larger main jets with the same rods. Has more power too.
I thought mine wasn't a lockup?
Agreed, it is not a lock-up converter, but the things which make the lock-up smoother also can make the shifting a bit smoother in normal automatics. Which can aso mean a better ATF with better base oils, too.
I think I read that THAT additive was not to be used on a non-lockup like mine.
Your transmission was spec'd for the old Type A atf. The GM Dexron family of atf replaced that spec in about 1968. The modern fluids are much better fluid than the old Type A atf, by a long shot. Better base oils, cleaning additives, anti-wear additives, and such.
To me, the amount of friction modifiers in the modern atf is not that large, as the lock-up torque converter only has one thing to match rotational speed with. In the normal shifting operations, there are items inside the transmission which completely start and stop when a upshift or downshift happens. THAT is a much heavier-duty situation, by comparison.
The existing, "red bottle", Valvoline MaxLife atf also has a bit of seal-swelling additives in it, as is. Which is the orientation of "higher-mileage" or older automatic transmissions needing something like that, due to age.
In the Sannow book on Mopar Police Cars, it mentions that in the earlier 1960s, the CHP got a new maintenance director. One of his "new things" was to standardize the various oils and such they bought, to more-standardize them. So he bought 20W motor oil, for engines and automatic transmissions. With the stipulation that if the car got into a high-speed chase, the car came in for a full engine and transmission oil change. He noted that the TFs had no issue running 20W motor oil, but the Fords and GM 3-speed automatics DID NOT like it. When I read that, I smiled.
LOTS of options!
When I worked at the dealer in 1969 the PA state police had Plymouths and Fords. When a trooper brought a Plymouth in for service he told me that at 85,000 miles a C-6 had to be rebuilt where a TF kept on going!
Drive it long enough to heat the wheels/drums up with your hubcaps off.
Carefully feel the centers of the wheels for one hotter to the touch than the others and find out why.
I was able to do your test today. FYI, the rear drums were just machined and the brake shoes are new but not arced. I've adjusted them to their loosest point and they were reasonably free spinning. I figure I'll just keep putting miles on them to break them in.
I drove around town quite a bit and I could hear the drivers rear brake howling slightly in and out when approaching a stop.
As I said before it would occasionally feel like the drums were out of round and sometimes not. I felt the center nut on the driver's side rear shaft and it was too hot to touch. The drum was hot too but not as hot. The passenger shaft was hot but not as hot meaning I could hold my finger on for a few seconds.
Are the bearing greased or bathed in gear oil?
Make sure you have the correct springs in the correct place on the brake shoes. The fronts use four coil and the rear use five coil springs and the front and rears attach to the brake shoes in different spots. The FSM makes it very clear.
Have you changed the differential oil? Very easy to do.
Early-Rear-Axle
Looks like the outer bearings should be greased.
Early-Rear-Axle
Yes, gear oil changed. I'll look again at the springs. Hoping the bearing isn't pressed on.
The bearing is pressed on but you can remove the brake backing plate and use one of those needle greaser things that you can put on the grease gun hose.
The brake adjusters, if I remember correctly, can be turned 360 degrees so if you back off too far you are essentially moving the brake shoes back toward the drum.
If your going to pull the drums again, verify the shoes are turned in all the way and mark the backing plate and adjuster so you know where you're at.
I don't know what the wrong springs or being mounted to the brake shoes in different spots on the front and rear wheels would do but they have the correct information in the FSM for a reason. What that reason is I don't know.
If you pull it apart to grease the bearings look for metal grindings around the bearings indicating failed bearings.
Well said. Too often we discard what the engineers decided simply because we don't think it matters.
Maybe it doesn't matter today or next week, perhaps it matters over 30k miles from now.
Yes, if you see debris- it has failed.
FWIW, the last failed axle bearing I had did not show any debris in the grease, but it sure did when I flushed it out with some solvent.
If the grease is old, it's worth getting all of that out and having all-fresh grease anyway.
If one uses compressed air to clean the solvent out, hold the bearing so that it doesn't rotate (or rotates only very slowly).
Compressed air can over-speed a bearing, esp if it's dry.
Thanks Jakter,
Since I got the car and because of this brake/vibration issue I've replaced the master cylinder, wheel cylinder on the problem side, and the rubber brake line at the drivers side rear axle that feeds both wheels.
An early problem was that the rear brakes especially the drivers side and especially when they were hot they'd drag more. That's why I replaced those parts. I've had the rear drums off and adjusted them to their loosest position and left them there. The brakes are still slow to release and I double checked the pedal free play which was fine.
There's an old Bendix power brake assist that looks to have been added long ago which does still work.
Today, I jacked the rear wheels off the ground and still see the brakes slow to release. When I crack the bleeder at the brake booster the wheel frees up. This indicates there's a little pressure in there that's not releasing correct? So today I took loose the brake line at the front junction to the rear axle junction and blew the line out with air and brake cleaner. No crud in the white bucket seen. I also checked the 2 lines from the master to the booster and booster to front junction, nothing obvious. I've also tried disconnecting the vacuum to the booster. I'm wondering if something in the booster is sticking?
Anyway, I've stopped for tonight and will check into the brake springs which I've checked before and bearing tomorrow. I suppose I could have 2 problems, a sticking booster and a bad bearing. The bearing would cause the pedal pulsation although I don't know why the would be part time? Both rear wheels while spinning to have a slight wobble but not sure this is normal for an old car. Question: when the drums are machined are they absolutely perfectly round and would not have a pulsation of ANY kind?
Nothing in the booster or anywhere else will cause the rear brakes to not release as quickly as the front ones do . . . except a rubber brake line that is in process of delaminating internally. Makes a very good one-way pressure valve. If that line has not been replaced, it needs to be. Even if the line was "new" or NOS, the rubber is still very old and can come apart from the internal reinforcing fabric web between the rubber layers. Of course, DO make sure the piston(s) in the wheel cylinder(s) is free and not binding. Some disassembly might be needed.
Did you replace the metal lines back there, too? Or check them for obstructions?
The after market Bendix brake booster is a separately mounted unit on the fender well and has the brake lines in and out attached to it so there must be some sort of helper piston in there?
After checking everything else I'll bypass it altogether.
Update: I bypassed the booster and viola! the brakes don't drag or get hot. Vibration is still there which is probably somewhere at either end of the drive shaft or emergency brake drum. As I stated before, my car didn't have optional power brakes, someone added the booster. Here's an example of what I had on ebay. Now it's back to manual brakes which isn't bad, just a little more foot pressure required. I think the pulsating I was feeling was the brakes getting hot and warping then cooling and straightening out.
