Hi Jeff,
When I was doing the sub frame connectors, I was really worried that they weren't going to put in straight, so that brought on the measure-fest. Using the diagonal method illustrated in the FSM, narrowed the variance down to the front left frame horn.
At the time this was done, the bushing were unknown years old, but still intact.
The idea behind putting these things together, is to make the car stronger, safer, and more stable at speed. I doubt much weight, and no cost will be saved. The car is getting a workout, from brake torquing in the burnout box to dropping off on the big end.
If you check the parts list, the 5/8"suspension tubes and ends. I spoke to a guy at Allstar who was very helpful. The stock nuts are 1/2", the new 5/8" should be stronger.
My experience with suspensions using these type tubes were both 4 links, one in a Mud Bog truck with 44s, and the other was my Max Wedge race car, with slicks.Same size tubes, maybe lesser quality ends were used.
I think it is overdone, but then again, that's why I posted this here.
A frame puller was an option I looked at. If there was someone I trusted I would try it.
I am still sandblasting and painting everything, maybe in the next 2 weeks I can get it back together.
Thanks for the help! (pic for attention)
